Hello,
I would suggest you add a function to enqueue move/delete operations into a list. So that one file after another will get moved/copied automatically. I'm often copying more than 1 large file. And it would be nice if I doesn't have to wait everytime one file gets finished before copying another. Think other people would value that function too.
Regards, Skipper
Cuelist for copy/move operations
Re: Cuelist for copy/move operations
There is a button Options in the Copy/Move dialog. When you click it, you'll see a checkbox labeled Wait until all other Copy/Move operations are finished. I think you'll find this option to be exactly what you're looking for. To check the checkbox using keyboard, you can press Alt+O,W (press and hold Alt, press O, press W, depress Alt), or you can save it as default.
Thank you. You're right. That's what I'm looking for. But how can set this option as default for every copy/move operation?
Skipper wrote:Thank you. You're right. That's what I'm looking for. But how can set this option as default for every copy/move operation?
