Hi there,
is there a way to select multiple files and send them to an extern editor?
I think at the moment this is only possible with an automation script...
But with Crtl-Shift-F3 or Crtl-Shift-F4 for selecting a (alternative) viewer/editor it would be more than great!!!
Thanks a lot!
Eva~
PS: I'm asking for this new feature, because I'm looking for a comfortable way to e.g. compare 2 files with WinMerge. The WinMerge (only 32bit version available) context menu won't be displayed under a 64bit system in Altap Salamander Window.
Send selected (multiple) files to editor
Re: Send selected (multiple) files to editor
You are looking for User Menu advanced parameters such as $(FileToCompareLeft).
See http://www.altap.cz/salamander/help/sal ... ize_usrmn/
Thank you very much Jan!
Great work!!!
But nevertheless, these features would be very nice to have:
1) The mentioned environment variables (from user menu) also in the editor and alternative viewer settings (e.g. selected files in Crtl-Shift-F3/F4).
2) The same context menu as in windows Explorer.
Thx a lot!
Eva~
Great work!!!
Thx a lot!
Eva~
You can start the editor, select the files and drag'n'drop them into the editor. Most editors support this way to open files.Eva Eden wrote:is there a way to select multiple files and send them to an extern editor?
OK, ok... Thx
But it's the task of a file manager to handle the file operations. I want to select the files and open them with an alternative editor/viewer. And this is exact the Ctrl-Shift-F3/F4 feature of Salamander.
Well, sometimes it's nice to be able to edit just the one focused file when there are others selected, so I definitely wouldn't like Salamander to this behavior by default without the option to disable it.
