WebDAV
Posted: 14 Mar 2006, 10:04
by RBX32
simple question: When will Servant Salamander support WebDAV?
Greets
RBX32
YES - pls add WEBDAV support!
Posted: 31 Aug 2006, 14:20
by lkindem
Agree... pls add WEBDAV support
Re: YES - pls add WEBDAV support!
Posted: 31 Aug 2006, 20:51
by bebe
+1 on this one
Posted: 29 Sep 2006, 11:32
by Buster
I'd like this too.
Posted: 01 Oct 2006, 14:57
WebDAV plugin is frequently requested, perhaps we should move it to ALTAP Roadmap.
Why is WebDAV useful for you?
Posted: 07 Nov 2006, 03:12
by Guest
This is an old thread, but I'll chime in:
WebDAV makes it very easy to support mapping remote drives for delivering/sharing files. And there's SVN integration, as well ... so this is useful for everyone from programmers to designers.
Posted: 29 Nov 2006, 09:58
by KNUT
Jan Rysavy wrote:Why is WebDAV useful for you?
Because, some
Free-Mailer provide a WebDAV-device (
www.gmx.net)
WebDAV
Posted: 01 Mar 2007, 05:10
by antoine
WebDAV is very useful for me too. My company is implementing an artifact repository (to store the jars and ears that we build). This artifact repository is hosted by an IBM HTTP server with mod WebDAV installed. With the WebDAV plugin, I would be able to manipulate the repository without using cadaver, a command line client.
Posted: 09 Mar 2007, 00:17
by Buster
WebDav also is a good replacement for FTP if the webserver already works with authenticating users against a 3rd party database and ftp doesn't.
Posted: 02 May 2007, 08:55
by La
in my context, almost everybody uses BSCW, a web collaboration solution.
The filestore is also accessible via WebDAV. This is much more convenient than downloading multiple files through a web frontend...
Regards
La
Posted: 09 Jun 2007, 14:35
by Ether
I'm not sure what WebDAV is in particular, but AFAIK it has to be activated on the server to work, right? Therefore I would appreciate a HTTP client, too. Browsing HTTP is a useful feature for downloading lots of files from a single directory on a server and so on... I use FlashGet for this (F7), but in AS it would be much comfortable. I think it could be integrated into the FTP plugin, just needs to integrate HTTP protocol and routine for extracting links from HTML files. I could even help with programming of this.
Posted: 09 Jun 2007, 17:59
by cincura.net
ether wrote:I'm not sure what WebDAV is in particular, but AFAIK it has to be activated on the server to work, right? Therefore I would appreciate a HTTP client, too. Browsing HTTP is a useful feature for downloading lots of files from a single directory on a server and so on... I use FlashGet for this (F7), but in AS it would be much comfortable. I think it could be integrated into the FTP plugin, just needs to integrate HTTP protocol and routine for extracting links from HTML files. I could even help with programming of this.
I have a big objections. FTP plugin should do FTP and *nothing* more. Adding HTTP protocol into FTP plugin will be - from my POV - big mistake and can bring a lot problems.
BTW in WinXP and higher is WebDAV implemented in system. So maybe can be added with browsing network ability, which is on roadmap, cause' maybe there will be some interface near this (just shooting).
And back to the HTTP protocol. If we take HTTP 0.9 and HTTP 1.0, these versions are pretty simple (the 1.1 too, but not so much) and if you're willing to contribute, you can take some friends/volunteers and create it as plugin.
Posted: 09 Jun 2007, 18:47
ether wrote:I could even help with programming of this.
Altap Salamander SDK is available, now it's your turn
The only thing we plan to add to FTP client is SSL support (FTP over SSL). So don't be worry the WebDAV plugin will be waste of time. Note: FTP plugin is strongly bound to FTP protocol.
For experienced developer it should be no problem to rewrite Demo Plugin (part of SDK) into simple WebDAV plugin.
Posted: 23 Jun 2010, 12:34
by KNUT
Jan Rysavy wrote:For experienced developer it should be no problem to rewrite Demo Plugin (part of SDK) into simple WebDAV plugin.
Any experienienced developer out there to provide a WEBDAV-Plugin?
Re:
Posted: 10 Nov 2011, 09:07
by KNUT
Jan Rysavy wrote:WebDAV plugin is frequently requested, perhaps we should move it to ALTAP Roadmap. Why is WebDAV useful for you?
For example WebDav is offered by
MyDrive.ch and
Cortado Workplace as a very nice (and free) service! Try it!
