Make File List: Provide a sensible default template
Posted: 06 Aug 2011, 20:54
It seems that when the history saving is disabled (Options > Configuration > History > Save history), there is no way to provide a default template for the Make File List command. So please, either provide a way to save a default template independently of history (as with the Save as directory in PictView plugin), or hardcode a sensible default, e.g. $(FileName)$(CRLF) (as with the Edit New File dialog).
