GodMode toolbar button
Posted: 20 Jun 2011, 02:07
by omega
Would it be possible to create a toolbar button for GodMode, a feature found in vista and win 7 ?
Re: GodMode toolbar button
Posted: 20 Jun 2011, 02:51
by otrov
You can create handy folder, then from Mode.{ED7BA470-8E54-465E-825C-99712043E01C} copy all item there. It will create shortcuts in that folder to all items from Mode.{###}
Posted: 20 Jun 2011, 15:00
by omega
Yes i know you can create a directory and copy all the shortcuts to the new directory and then create a hotpath. What you don't get is the categories that you see when you open the GodMode directory in windows explorer. So an optional GodMode toolbar button is something nice to have just like the control panel toolbar button. :)
Posted: 20 Jun 2011, 16:45
by th.
You can create a User Menu entry:
Command: explorer
Arguments: shell:::{ED7BA470-8E54-465E-825C-99712043E01C}
Execute through shell: unchecked
Posted: 20 Jun 2011, 17:39
by omega
Cool, thanks mate. :D
