Can the IFileIsInUse Interface be used in Salamander?
Posted: 24 May 2011, 00:32
by Andre.Ziegler
If an app implements the
IFileIsInUse Interfacethe Explorer shows which program has the file open if you try to move or delete that open file. Can this be used in Salamander, too like in this competitive tool
http://blog.speedproject.de/2007/06/15/ ... verwendet/ ?
Re: Can the IFileIsInUse Interface be used in Salamander?
Posted: 24 May 2011, 07:58
by therube
Posted: 24 May 2011, 22:46
You should be aware of
Unlocker
(Do a custom setup, as there is some add stuff added. Also some antivirus programs may alert you because of this. The program it self is just fine.)
Posted: 26 May 2011, 23:15
by Andre.Ziegler
I don't need unlocker, I use ProcEx to search for the handle and close it. I'm here in the Feature Request forums so I want to request that feature and no workaround.
