Save window position for other viewers than Internal and Db
Posted: 09 Oct 2010, 22:26
Separated from another thread: Problem with word wrap and viewer's windows size
otrov wrote:I also have question for saving window state on viewers: is window state (if set in options) remembered only for internal viewer? For example if I set the window size of database viewer, the state is not saved but it always starts maximized, even more if I restore the window it does not restore to some previous state but always like top half vertical size. Does this make sense? Or is this happening only here.
otrov wrote:Yeah, viewer's windows are restored on the size main Salamander has, if restored. I was thinking that viewer's windows should remember it's own restore size, but this is also OK
Internal viewer has this as a setting in main configurations dialog, while Database viewer also has this option, but in Plugin Manager's configuration option
