FTP panel option -- view filenames as they're stored on disk
Posted: 17 Feb 2006, 19:07
I like working with SS configured to show file names in lower case, with directories in upper case. Under Windows, case doesn't matter. And I can right-click a file, choose Properties, and see the file name as it's stored on disk.
But now that I can FTP to computers where case does matter, the setting is a great hindrance. It would be great if one of the following were available:
1. Right-click to show properties of a file on a remote FTP server. This would show the file name in the case as it's stored on the remote drive. (Ctrl-F2 should show it this way, too.)
2. Add a new configuration setting that allows for different display of case for local file names / directories versus remote file names / directories. This way one could set local file names to display as lower case with local directories in upper case. And the setting could be different for remote drives and FTP servers -- show names as they're stored on disk.
For now I'll probably change the setting manually each time I connect to an FTP server.
TIA
TIA
