Separator between right-click menu Delete/Rename items
Posted: 14 Jun 2018, 10:12
I often need to rename files, and do so by right-clicking the file then selecting Rename. Unfortunately Delete is just above Rename and, from time to time, I will accidently delete the file I wanted to rename. Luckily I can recover the file through the Recycle Bin so it is more of an irritation than anything else.
It would be great if a separator could be introduced between the Delete and Rename menu items to make it a bit more difficult to click Delete by mistake.
Cheers,
Brett
Cheers,
Brett
