I've scoured the help file and experimented at length trying to find a way to control the panel split ratio via keyboard. Is there any way at all to do it?
If there's not already, something like Ctrl+Alt+Left and Ctrl+Alt+Right would be possibilities since they don't seem to be used for anything else at the moment.
I know about Ctrl+F11, which I use regularly, but that only toggles between 100% and the previously-selected ratio, which can only be set by mouse, which is what I'm trying to find a keyboard way to do.
Split bar via keyboard?
Re: Split bar via keyboard?
It is not possible, I will move this thread to feature requests section.
Ok, thanks for your help!
