Ctrl+Alt+F11 in Find
Posted: 08 Apr 2009, 10:58
by mdruiter
Could Ctrl+Alt+F11 (FullScreen) perhaps also be made to work in Find?
Re: Ctrl+Alt+F11 in Find
Posted: 08 Apr 2009, 13:06
by MartinS
Strange, unlike in Explorer (Vista), in my AS it is Ctrl+Shift+F11
EDIT: But in Internal Viewer it is only F11, which is windows standard (works in Explorer too)
In Find it is unfortunately missing...I think F11 should be added
Posted: 25 Aug 2009, 14:05
by mdruiter
Maybe both Ctrl-Shift+F11 *and* F11!
Posted: 08 Dec 2009, 23:14
by mdruiter
MartinS wrote:Strange, unlike in Explorer (Vista), in my AS it is Ctrl+Shift+F11
I did not realize until now, that I typed Ctrl+Alt+F11 where I meant Ctrl+Shift+F11.
Posted: 07 Jun 2010, 11:46
by mdruiter
MartinS wrote:I think F11 should be added
I think at least F11 should be added.
Adding Ctrl-Shift+F11 too would be a usability bonus.
Posted: 10 Jun 2010, 12:48
by KNUT
I use
WindowPad for all window-arrange-issues. Very easy to use (no-install), customizable (hotkeys), small and works with ALL windows.
Posted: 11 Jun 2010, 09:11
by th.
I find myself getting used to the new shortcuts for window arrangement in Windows 7.
Posted: 12 Jun 2010, 17:20
by SvA
th. wrote:I find myself getting used to the new shortcuts for window arrangement in Windows 7.
Are you talking about keyboard shurtcuts (I do not know of) or about mouse gestures and dragging the window to borders?
Posted: 13 Jun 2010, 23:22
by th.
They have introduced keyboard shortcuts like
- Win+Up = Maximize,
Win+Down = Restore/Minimize,
Win+Shift+Left/Right = Move to another monitor.
See
http://windows.microsoft.com/en-US/Wind ... -shortcuts for a reference.
Posted: 14 Jun 2010, 10:37
by mdruiter
I use Vista so it doesn't help...
Posted: 14 Jun 2010, 12:28
by th.
BTW has anyone ever used the Alt+Space sequences?
Posted: 14 Jun 2010, 12:48
by Slanec
th. wrote:BTW has anyone ever used the Alt+Space sequences?
Shift+ESC, all the time
Posted: 14 Jun 2010, 16:21
by mdruiter
Yes, I do
Shift+Space, x as long as F11 does not work.
Slanec wrote:Shift+ESC, all the time
You mean "Minimize the main window of Altap Salamander"? I never want Salamander (or any of its windows) minimized.
