Amazon S3
Posted: 24 Feb 2009, 08:48
by Bigphili
Are there any plans to add Amazon S3 support to Salamander?
Re: Amazon S3
Posted: 29 Jan 2013, 23:11
by rsignell
I guess since more than 3 years have passed, it's time to ask this question again: Any plans to support Amazon S3?
It would be really handy to drag-n-drop files over to S3 storage and back.
Re: Amazon S3
Posted: 21 Feb 2013, 22:00
by Ether
There are several ways (that I know of, there may be more) to implement the functionality you request:
- a brand new plug-in - you'd need to get some programmer(s) to work on that, but there probably won't be anyone with enough interest, unless the other options don't work (or work horribly)
- the TC Proxy plugin + a Total Commander plug-in - you can try it (for instance this one), but there are no guarantees
- integration into the WinSCP plugin - not likely
- the Folders plug-in and a shell extension - the plug-in is not likely to be released in the near future and I couldn't find any such shell extensions (but that was during my one-minute Google search; you may be more successful)
- an application that can create virtual drives - you can try some right now (TntDrive, Amazon S3 Filesystem...)
