WildCards in quick search
assaf azoulay
Post by assaf azoulay »
hi to all
i'm really enjoying this great software,but i have
something that bothers me allot
when you search for file in quick search you cant use wild card
for example if you have a directory with the file:
song-radiohead-creep.mp3
you cant just type *creep to get quickly to the file (like in total commander) instead you can only press: song to get to the file
one more thing if you try to search with ctrl+f and then focus on song
you will discover that you need two wildcards for example *creep*
and not just one.
hope you will improve this since its a very basic needed feature of a
file manager.
other features are great. keep working for all of us.
th.
Post by th. »
In quick search the wildcard keys are slash (/), backslash (\), or less than (<) character (see help file under "Quick searching").
In the find file dialog you can use "creep" instead of "*creep*" to get all files with creep anywhere in the filename (I think this is not written in the help file).
assaf azoulay
thanks
thanks! its working !! :D :D
