Add CVS Tortoise cvs-state-columns in Configuration\Views
Hello Salamander team,
please would you be so kind and think about following:
CVSTortoise adds CVS-columns in Windows XP explorer (look in more... in right mouse button columns choose in XP explorer).
It will be very helpfull to add this columns in Salamander to for users having CVSTortoise installed.
So one can see CVS file-status in Salamander.
Not only in the next version prepared "Icon overlays (TortoiseCVS, TortoiseSVN)" but the columns too please.
R.S.V.P.
roman
p.s. Btw.: choice from all the xp columns
R.S.V.P.
roman
CVS-overlay-icons etc.
I aggree with roman, that its important that servant salamander can show the (tortoise) CVS specific entries for CVS-controlled files and folders. For now i still need the windows explorer to manage CVS-data.
Greetings, Torsten Blank
Re: CVS-overlay-icons etc.
Agree with Roman & Torsten: (tortoise) CVS specific icons for CVS-controlled files and folders would be very helpful. For now still need to use the windows explorer to manage CVS-data.
Supporting CVS/SVN
No doubt that it would be nice to have icons-support for Tortoise.
Is this functionality found in your road map? If found, how high up? I’m trying to persuade my colleges into using CVS/SVN. Bundled toegether with SS they may grow to like it easier.
An alternative to shift-f3: I still use SS for most operations but when needing CVS (is SVN that much better?), I right click the source directory and choose the Windows !"¤#&¤!"%#¤ Explorer. I find this quicker that the short-cut.
Go home Total Commander!
Re: Supporting CVS/SVN
Yes, it is. We will a open poll for Salamander's 3.0 features. We suppose this will be highly demanded feature.hrc wrote:Is this functionality found in your road map? If found, how high up?
When do you plan to release this 3.0 version? Is it possible to purchase version 2.0 now and have free upgrade to 3.0 when it will be available?Jan Rysavy wrote:Yes, it is. We will a open poll for Salamander's 3.0 features. We suppose this will be highly demanded feature.hrc wrote:Is this functionality found in your road map? If found, how high up?
Tortoise SVN
+1
I am a heavy Salamander user since 1999 and my client forces us to use TortoiseSVN. Its nice the right click menu options are available through salamander but the icon notation is really the power of Tortoise to show me what has changed. this feature would be greatly appreciated!
