Process viewer plugin
Posted: 26 Jun 2006, 09:21
by eblis
Could you add a process viewer plugin with end/kill posibility - available in the drive menu, like the Registry browser ?
Posted: 26 Jun 2006, 16:42
by AbteriX
Hi eblis,
you could use the user menu
and add tools like
PrcView or ProcExplorer or ProcessMate or ProcX or...
Posted: 26 Jun 2006, 16:44
by eblis
Yes but that starts another program. I was thinking altap would show the processes in the panel, just like it shows registry keys in the registry panel.
I see you've replied to my other threads too
... are you familiar with Far ? most of my suggestions are based on that file manager, maybe you could take a look and see what i mean (if you're not familiar with Far already).
Re: Process viewer plugin
Posted: 27 Jun 2006, 08:52
by KNUT
eblis wrote:Could you add a process viewer plugin with end/kill posibility - available in the drive menu, like the Registry browser ?
IMHO a process viewer ist completely obsolete in a
File-Manager...
Posted: 27 Jun 2006, 09:37
by Josip Tosic
Not useless if it'll let us find the process that locked a certain file.
I simply gave up and use Process Explorer with "Replace Task Manager" feature enabled.
Posted: 27 Jun 2006, 13:19
by omega
I have never used Far before but as you said most of your suggestions came from that NC like file manager. Did Far show the processes in the panel?
Posted: 27 Jun 2006, 15:17
by eblis
Yes, Far showed processes in the panel and you could terminate them using the "delete" key. You could also search through them iirc.
Anyway, this is not such a big deal ... maybe some other developer(s) will take up the task once Altap release the SDK
