Rename files Vista-style
noetus
Post by noetus »
My feature request: when pressing F2 to rename a file, have it highlight the NAME only without extension, as in Windows Vista rename, so you can simply type a new file name to overwrite the old while keeping the file extension. Would be easy to implement!
jocare
Post by jocare »
This is already done with RC3; now I need it selecting both the name and the extension in order to copy the filename somewhere else. Would it be posibe to chose?
Josip Tosic
Post by Josip Tosic »
Instead of going into Quick Rename and copying the full file name, select the file and press [Alt]+[Shift]+[Insert].
Please continue in this thread: http://forum.altap.cz/viewtopic.php?t=1964
Locked.
Locked
