Your program is great! There are many features I couldn't live without anymore, e.g. "Batch Rename" (very sophisticated) or "Picture View" etc.
There's only one thing I'd like to find in future versions of Servant Salamander: I'd appreciate the possibility to automatically show the number and size of all files in any chosen directory (like in the status line of the Windows Explorer). Of cause you can find out by pressing "strg + a". But if there are files and subdirectories then  you get only the number of either of them, but not their size. I find it's a bit of an inconvenience that you've got to think of such matters.
						Information Line improvements
Re: Information Line improvements
There is another thread dealing with this, just don't have the URL at hand. Is pressing SPACE instead of INSERT key what you're missing?Anonymous wrote:There's only one thing I'd like to find in future versions of Servant Salamander: I'd appreciate the possibility to automatically show the number and size of all files in any chosen directory (like in the status line of the Windows Explorer).
/Georg
Using Salamander since v 1.52
