Why would you expect the format to be one <whatever> per line? Why not separated by the locale's list separator, or quoted and separated by space, or separated by comma, or in OEM rather than in ANSI codepage or ... ?wqweto wrote:The family of `Copy ... as Text` actions under `Edit` menu does not work as expected when multiple files are selected. If a selection is present in current pane (red rows) it would be very handy if all names/path+names are copied on separate lines in the clipboard.
Copy Path + Name as Text (Alt+Insert) enhancements
Re: Copy Path + Name as Text (Alt+Insert) enhancements
Interesting thread.  I only have the one hand now: car accident created MOUSE-ONLY usage.  Keyboard is clumsy, compared to mouse-clicks.
Instead of the "(Alt+Insert) enhancements", I use:
(1) "CopyPathSetup.exe", 607 KB (622,271 bytes).
The url is: http://download.cnet.com/CopyPath/3001- ... 37174.html
It works for all file managers, I think, as a right-click choice. There are others as well, with more choices, but I don't use them
(2) PathCopyCopy 15.0.exe 1.29 MB (1,353,847 bytes)
(3) Pathc400,
(4) CopyFileName 2.2.0.22 1.98 MB (2,084,472 bytes)
(5) FullPathCopy 1.0.exe 911 KB (933,520 bytes)
(3) Pathc400,
Retired (1985) Chief Information Officer, Australian Capital Territory.
FYI, related posts with different solutions are:
							Using Salamander since v 1.52
