pre-select file name (without ext) in Quick Rename dialog
egbert
Post by egbert »
more often than not, when renaming a file, I don't want to change its extension but only the name part (e.g.: renaming file1.png to file2.png).
When 'Quick Renaming' (F2) a file, the entire file name is pre-selected so I have to manually mark the name part to achieve what I want.
O.k., it's really not that annoying, but being spoiled by all the convenience Servant Salamander offers, this tiny flaw stands out :wink:
What about having the Quick Rename dialog pre-select only the name part of the file name, not the extension part?
Regards,
Egbert
KNUT
Post by KNUT »
nice idea, but not a "must have"
Kind regards, KNUT
PepaR
Post by PepaR »
Yes, I vote for it...
zxspectrum
Post by zxspectrum »
Yes, i kinda like that ideaa too.i use very often quick rename especially when i want to make a directory after an archive name or mp3, and i always manually delete the extension from quickrename.
Tomcat
Post by Tomcat »
I also raise my hand and vote for this feature. I guess that I keep the extension in 90% of my rename operations.
Currently there are two ways to 'quick rename', the F2 key and the single click onto a seleted filename (windows explorer style). If one of these (preferably per F2 ) could highlight all but the extension there would be both options available in SS.
hotdog
Post by hotdog »
Tomcat wrote:I also raise my hand and vote for this feature. I guess that I keep the extension in 90% of my rename operations.
Make that 99% for me! I think we should vote for this one. A must-have feature and not really hard to implement Altap guys... :roll:
Ahh! Can you include an option in the confirmations dialog that would look like "When renaming do not allow names longer than 64 characters (CDFS compatibility)" for people who regularly write files (such as mp3s) to CD/DVDs and there is a restriction in the filenames which doesn't allow them to exceed 64 characters in length?
omega
Post by omega »
Don't think it's a flaw plus are song names that long 64 chars?
freckyo
Post by freckyo »
I vote for this feature, too! When the user wants to change the file's extension instead, he can press the end-key and the pre-selection will disappear + the cursor will be positioned to the filename's end.
Josip Tosic
Post by Josip Tosic »
Maybe a "new" dialog that'd only display the filename? With a new shortcut? [Shift]+[F2]?
Or, maybe a better idea, display filename and extension in separate textboxes and preselect the contents of the first textbox (filename)? User could simply [Tab] into the next textbox and extension would be preselected.
AbteriX
Post by AbteriX »
I learned this behaviour for my own use:
1.) F2
2.) 4 times "Arrow left"
3.) Shift+Pos1
4.) wrote new name
5.) ENTER
or
1.) F2
2.) more times "Arrow left" --- or mouse click on the desired place
3.) modify
4.) ENTER
But i grant i think about Josip second suggestion first time i read this thread, too :lol:
AbteriX
KNUT
Post by KNUT »
AbteriX wrote:I learned this behaviour for my own use:[...]
I did it my way:
1.) F2
2.) POS1 (HOME)
3.) CTRL+SHIFT+LEFT
4.) SHIFT+LEFT (that means to only release the CTRL-Button)
5.) write the new name + ENTER :o
or
1.) F2
2.) write the new name + ".*" + ENTER :shock:
Kind regards, KNUT
AbteriX
Post by AbteriX »
I did it my way:
1.) F2
2.) POS1 (HOME)
3.) CTRL+SHIFT+LEFT
3.) CTRL+SHIFT+RIGHT <= you mean :D
WOW, nice too !
especially for names without spaces.
or
1.) F2
:shock: you'r right, think DOS :shock:
I try to remember this tricks :!:
AbteriX
KNUT
Post by KNUT »
AbteriX wrote:
KNUT wrote:I did it my way:
1.) F2
2.) POS1 (HOME)
3.) CTRL+SHIFT+LEFT
For sure :oops:
WOW, nice too !
ONLY for names without spaces!! :(
Kind regards, KNUT
What about
1.) F2
2.) CTRL+SHIFT+LEFT
3.) SHIFT+LEFT (that means to only release the CTRL-Button)
4.) write the new name + ENTER
You may leave out step 3 and add the dot again before pressing enter.
Spaces and the like in extensions are very rare.
Tomas Kopal
Post by Tomas Kopal »
1.) F2
2.) POS1 (HOME)
SHIFT+HOME in step 4) will take care of the spaces, but the key is a bit farther away ;-).
