I miss WinSCP
Forum rules
richb
I miss WinSCP
Post by richb »
I been using Salamander 3 64-bit since December. I don't really miss Eroiica viewer, because the quality was pretty bad so I didn't use it.
But, I DO miss the WinSCP plug-in. I know it's simple to install WinSCP.exe and launch via the user menu. But unfortunately you can't get WinSCP to launch with a specified local directory (ie. the directory of the current Salamander tab). So, one for the wish list.. either bring back the WinSCP plug-in, or provide some way to launch WinSCP starting at the specified directory.
Re: I miss WinSCP
According to this Czech post about 64-bit WinSCP plugin, the main roadblock in porting the plugin to 64-bit Salamander is gone, but there's no ETA for the plugin at the moment.
As for the capability to launch WinSCP with specified local directory, I have tried it before a few times and couldn't come up with a way to do it. However, it was a while back and I didn't spend much time on it, so maybe it's possible. You should have more luck if you visit the WinSCP Forums and look for the answer there. If you happen to find a way, I'd be happy if you posted it here, too.
richb
Re: I miss WinSCP
Post by richb »
Thanks, I started on thread on the WinSCP forums. We'll see if anyone can help.
http://winscp.net/forum/viewtopic.php?t=12233
crystalidea
Re: I miss WinSCP
Post by crystalidea »
Can't use x64 version only because of missing WinSCP there
Re: I miss WinSCP
Yes, we miss it too. We hope Martin Prikryl will convert WinSCP to x64 platform.
crystalidea
Re: I miss WinSCP
You could use x86 process to work with WinSCP and proxy x64 spl plugin that uses IPC to connect to this process
PS this technique could be probably used to support other x86 plugins
Re: I miss WinSCP
We are using this technique in PictView plugin and it could be used for the Eroiica Viewer, but for WinSCP plugin it would be too complicated.
Melloware
Re: I miss WinSCP
Post by Melloware »
Any update on this? It looks like WinSCP was finally able to compile 64 bit version using the latest C++ Builder?
I would love to have this plugin back in the 64 bit Salamander!
Melloware Inc.
http://www.melloware.com
crystalidea
Re: I miss WinSCP
The only reason why I'm still using 32-bit version of AS
Moder_20
Re: I miss WinSCP
Post by Moder_20 »
Same..
crystalidea
Re: I miss WinSCP
3 years without WinSCP in 64-bit AS
zorglups
Re: I miss WinSCP
Post by zorglups »
Looking at this thread, I'm afraid the WinSCP x64 version is not for tomorrow :-((
https://winscp.net/forum/viewtopic.php?t=4654
Would you suggest or implement an alternative?
Thanks,
Pierre
crystalidea
Re: I miss WinSCP
zorglups, I posted this link >3 years ago here (see above)
Melloware
Re: I miss WinSCP
Post by Melloware »
It looks like the win scp developer just posted recently and it sounds like he is working on 64 bit
Melloware Inc.
