PB87: AVAST blocks Self-Extractor
Posted: 23 Nov 2012, 07:51
by polyakoff
I use AVAST antivirus and it blocks creating of Altap self-extracting archives and it also blocks opening of such archives.
AVAST v.7
Altap Salamander 3 beta 1 PB87
Re: PB87: AVAST blocks Self-Extractor
Posted: 23 Nov 2012, 18:45
by therube
Recent occurrence, as in with a definition update?
So it is detecting zip.spl?
Have you reported it to AVAST as a false positive?
Posted: 24 Nov 2012, 12:47
by Ether
therube wrote:Have you reported it to AVAST as a false positive?
Reported.
therube wrote:So it is detecting zip.spl?
Nope, none of the files in the
plugins/zip directory. It detects the file created during making of a SFX archive. There's no virus warning with v2.54.
Posted: 25 Nov 2012, 16:37
Note: Altap Salamander 2.54 was build with Visual C++ 6.0 instead of Visual C++ 2008 we are using for Altap Salamander 3.0 - there will be differences. Thank you for reporting to ALWIL.
