PB79 Thumbnail View
Forum rules
nighthawk
PB79 Thumbnail View
Post by nighthawk »
If i switch the folder view to "thumbnail" no preview is shown with picture files like jpeg etc.
Salamander only shows the icon of the associated program (irfanview in my case)
Works fine in 2.54.
Dirk
Re: PB79 Thumbnail View
Thumbnail are provided by the PictView plugin (not included in x64 version) so it works only in the x86 version of Altap Salamander.
We are working on x64 PictView version.
Jan Rysavy wrote:Thumbnail are provided by the PictView plugin (not included in x64 version) so it works only in the x86 version of Altap Salamander.
For the record: The 64-bit early-access version released at the end of July 2012 (i.e. few days after this post) already contained PictView.
roberto.anzola
Post by roberto.anzola »
Hello, I'm using A.Salamander 2.54 but I cannot see the thumbnails in the right frame. I looked in the Plugin list and do not see PictView.
I also tried several places for the download as suggested in the various posts but no luck.
I'm running on windows 7 64 bit.
Any good hint?
roberto.anzola
Hello as i cannot see PictView either the thumbnails in the right screen. Was PictView delieverd meanwhile? I use Salamander 2.54
roberto.anzola wrote:I looked in the Plugin list and do not see PictView.
In Altap Salamander choose Plugins > Plugins Manager command. Click the Add button. Choose pictview\pictview.spl file and click Open button. It should add PictView plugin into Altap Salamander 2.54.
roberto.anzola
Jan, thanks but i tried that alreday a while ago but I do not have the SPL. Maybe is because is not licensed to us? (ISIS Papyrus Europe).
Can we talk via email? *email deleted*
thanks
Yes, it seems so. I will contact you on email.
