AS 3.0 PB75 - Network copy speed test
Posted: 10 Apr 2012, 12:29
We would like to ask you for comparing AS 2.54 / AS 3.0 PB75 / Windows Explorer network copy speed.
Copy the same large file over your network (wired or wireless) and take Task Manager screenshot as we did in
http://forum.altap.cz/viewtopic.php?t=5447
We have report (Czech only) about slowdown introduced in AS 3.0 PB75:
http://forum.altap.cz/viewtopic.php?f=16&t=5493
How does AS 3.0 PB75 work on your network? Please let us know...
Re: AS 3.0 PB75 - Network copy speed test
Posted: 10 Apr 2012, 15:44
by MartinS
1,01GB file over 100Mb/s local network, Win7CZ
1. AS 3.00x64, Avg. speed 10,60 MB/s
2. AS 2.54, Avg.speed 3,05 MB/s
3. WE, Avg.speed 11.10 MB/s
Edit: copying from my Notebook to Win2008 server. I will test the oposite direction later...
Posted: 10 Apr 2012, 16:43
by ino
MartinS wrote:1,01GB file over 100Mb/s local network, Win7CZ
Are those data from upload or download? Could you test the opposite way as well. I have encouraged problems while downloading file from remote to local drive in the Czech post.
Posted: 12 Apr 2012, 09:00
by MartinS
And now opposite direction from Win2008 server to notebook
1. AS 3.00x64, Avg. speed 11,0 MB/s
2. AS 2.54, Avg.speed 10,1 MB/s
3. WE, Avg.speed 11.3 MB/s
Posted: 11 Jul 2012, 09:04
by mito
Test in 100Mbit LAN at work. Test in Gigabit LAN at home will follow ...
Writing speed to network seems to be O.K. But strangely older Salamander is faster in reading from network than the public beta
Re: AS 3.0 PB87 - Network copy speed test
Posted: 17 Sep 2012, 21:13
by thomas
Test System: Windows 8 Professional x64 Bit / AS 3.0 PB87 / 1 GBit Lan
Slow copy speed of a file with Salamander.
- Salamander1.png (572.42 KiB) Viewed 11631 times
- Explorer1.png (475.23 KiB) Viewed 11631 times
Posted: 17 Oct 2012, 15:53
by thomas
Meanwhile I have tested some more other file manager. None of them had shown this problem with the low copy speed.
Could you solve the problem?
Posted: 27 Nov 2012, 08:44
by mito
I have no more hope, because I started an thread with the same problem in December
2011 here (
http://forum.altap.cz/viewtopic.php?f=2&t=5252) and nothing happened
Posted: 07 Feb 2013, 05:27
by therube
Ran across this - FWIW;
15 Free File Copy Tools Tested for the Fastest Transfer Speeds.
(No I'm not promoting anything or any method, but just look at the [often quite] varying results obtained by all these products promoting, in the broadest sense, "speed".)
Posted: 07 Feb 2013, 07:48
by Petr Solin
Thanks, interesting test! We will patch our copy routine to use more simultaneous transfers at one time to get better network performance, so we may try to compare it with some of these tools.
Posted: 29 Jun 2013, 07:06
Faster asynchronous algorithm is implemented from
Altap Salamander 3.0 beta 3 (PB103).
Please test it across your networks and let us know in a new thread if you find any problems. Thank you.
