AS 3.0 (PB75 x86) - Malware warning (AVIRA)
Posted: 05 Apr 2012, 16:51
by SvA
AVIRA Antivir Personal reports a trojan horse TR.ATRAPS.Gen in the download file as30b1pb75x86.exe and in uninstpl.exe on install.
(Just so you know)
Re: AS 3.0 (PB75 x86) - Malware warning (AVIRA)
Posted: 05 Apr 2012, 17:01
It is a bug in AVIRA. Please contact AVIRA support or consider another antivirus.
Thank you for the info
Posted: 08 Apr 2012, 22:01
by ku
SImilar message in salbreak.exe with the f-secure antivirus during install. Installation is not possible without antivirus switched off.
Regards
Ivan
Posted: 09 Apr 2012, 09:26
Could you please show us the f-secure antivirus message? Is it "TR.ATRAPS.Gen" again?
Posted: 09 Apr 2012, 10:47
Latest
ESET NOD32 Antivirus and free
Microsoft Security Essentials work fine. No false positives issues.
Posted: 09 Apr 2012, 23:36
by ku
- Antivirus message
- Výstřižek.JPG (20.46 KiB) Viewed 16388 times
Jan Rysavy wrote:Could you please show us the f-secure antivirus message? Is it "TR.ATRAPS.Gen" again?
It is "Trojan.Peed.Gen".
Ivan
Posted: 10 Apr 2012, 00:40
by therube
Yes, "Trojan.Peed.Gen".
VirusTotal:
salbreak.exe
Posted: 10 Apr 2012, 07:59
I found False Positive web page for F-Secure:
http://www.f-secure.com/v-descs/other_w ... tive.shtml
Please submit the salbreak.exe to the mentioned Sample Analysis System (SAS).
Posted: 10 Apr 2012, 08:03
Posted: 10 Apr 2012, 09:59
by ku
I did it. Hopefully they repair it. If you check salbreak.exe wtih virustotal, you will see that 5 out of 40 antivirus detects this program as malware. In my experience even if you submit this problem to all of this antivirus companies, this problem will periodically return.
virustotal results -
https://www.virustotal.com/file/37c2c29 ... 334044039/
Best Regards
Ivan
Posted: 10 Apr 2012, 10:06
Thank you! We didn't know about
virustotal, it looks great.
Posted: 10 Apr 2012, 23:36
Jan Rysavy wrote:Thank you! We didn't know about
Then you might also add
http://virusscan.jotti.org/en to your bookmarks...
