AS3.0 beta 3 (PB103 x64) and Beyond Compare
Forum rules
Evin
Post by Evin »
If I open the context menu inside AS3 there should be the Beyond Compare, but no (Windows 8 x64). Everything still works fine, until I close AS3. Than automatically start the Bug Reporter, where I already sent in a bug report from this. I didn't tested under x86.
Re: AS3.0 beta 3 (PB103 x64) and Beyond Compare
Are you using a 32-bit version of Beyond Compare?
Beyond Compare have an x64 version?
(32/64 bit-ness sucks.)
Evin
Post by Evin »
As far as I know, BC has only one version, x86, but it has x64 shell extension.
I already had problem under Win8 x64 with AS3 x64 and BC3, but that fixed by the BC developer team. This problem appeared now, after I installed this latest AS3 beta.
richb
Post by richb »
I also have this problem. Beyond Compare shell context menu worked fine with beta 2. But with beta 3, the context menu item for Beyond Compare is missing.
Please check if you have latest Beyond Compare 3.3.8, build 16340, released June 19, 2013 and let us know. Thank you.
Evin
Post by Evin »
I have. I use the latest BC since the release, and worked fine with the earlier AS3 beta. Now happened something with this AS3 beta.
richb
Post by richb »
Yes I am on Beyond Compare 3.3.8, build 16340.
Also I should mention I am running AS x64.
