Column with another language in Texts window
Posted: 06 Sep 2010, 11:21
by Pasha T.
Can you add Column with another language in Texts window to compare translated text?
Re: Column with another language in Texts window
Posted: 06 Sep 2010, 14:00
by therube
Not sure what you mean?
Posted: 06 Sep 2010, 15:14
by Petr Solin
There are only original and translated texts, so two columns. What should be in the third column?
Posted: 06 Sep 2010, 15:34
Note: you can start two instances of Altap Translator with different projects. This way it is possible to compare two (or more) translations.
