Page 1 of 2
French Translation of Altap Salamander
Posted: 01 Aug 2010, 19:36
by ADB
Contact, Infos and cross-thinking for French translators. I suppose it may be allowed to write in French
Re: French Translation of Altap Salamander
Posted: 01 Aug 2010, 19:50
^^^ Feel free to discuss language translations in your native language.
Posted: 17 May 2011, 13:56
by Petr Solin
We have just received Salamander and TAR translated to French from G.G. Many thanks to G.G.! All other plugins need to be translated, if anyone would like to help with it, we would be very glad.
Posted: 17 Jan 2012, 19:56
by ADB
Hi
Which plugin have to be translated first?
I could do some work.
ADB
Posted: 09 May 2012, 11:07
by ADB
Hello everybody
I had some time to further translate new modules:
peviewer, ieviewer, automation
I intend to continue...
Best regards
Posted: 12 Oct 2012, 11:01
by bromatofiel
Hello,
I have some suggestions regarding the french translation of the error message displayed when the register is corrupted.
"Impossible de chargée la configuration enregistrée dans le registre car elle est altérée" -> "Impossible de charger la configuration enregistrée dans le registre car elle a été altérée"
"Altap Salamander a été sans doute interrompu aucurs de la sauvegarde de cette configuration" -> "Altap Salamander a sans doute été interrompu durant la sauvegarde de cette configuration"
"avant l'arrêt du système lui-même" -> "avant de demander l'arrêt du système"
"Ultérieurement, il sera loisible de récupérer" -> "Ultérieurement, il sera possible de récupérer"
Thanks for the good work !
Regards,
Posted: 25 Oct 2012, 08:52
by Petr Solin
Thanks! ADB has corrected it in French language file.
We are still searching translators for French version, if you can help, we will be very glad.
Posted: 07 Dec 2012, 07:15
by Maxime
Hello,
As I said on this previous old topic:
http://forum.altap.cz/viewtopic.php?f=23&t=691
I can help with the French translation (starting with the first window I had, the WinSCP evaluation warning).
I downloaded the latest Altap Translator.
But I have a question: how will you manage concurrent translations?
I mean, if I translate or correct some strings, send the atp file back to you, while Arnaud (or any other translator) is doing the same, how could you merge our efforts?
I suppose you don't have some common source repository like SVN, and it would be complicated to use such a tool as the slg files are binary stuff...
I don't really want to interfere with other translators' work and I will participate only if I'm sure that I'll not have to worry about that point.
Thanks for your answer.
Maxime
Posted: 07 Dec 2012, 07:58
by Petr Solin
At first, please wait for Altap Translator for 3.0 beta 1, we have not released it yet, sorry for delay, but we were working on SDK for 3.0 beta 1. We will release it today.
Team translation: please try to split the work, send your suggestions (which modules you want to translate) to this forum or directly to ADB email. Each translator should translate his own modules to prevent collisions.
The result of translation is .slt file (see readme.txt in Altap Translator package for details). It is UTF8 text file, so it is no problem to see your differences against ADB version of this file e.g. in File Comparator plugin. If you want to correct something, you should contact ADB to consult it with him. We cannot judge what variant is better, unfortunatelly we don't know French language.
When you send me .slt files, I'll place them on our internal Hg repository, so all versions are available if someone wants to compare them, etc.
Please follow these steps and I'll send you temporary registration keys for translators which unlock trial version:
http://forum.altap.cz/viewtopic.php?f=23&t=4067
Thanks for helping us with Salamander!
Posted: 07 Dec 2012, 15:51
by Petr Solin
Altap Translator for 3.0 beta 1 is ready to download:
http://forum.altap.cz/viewtopic.php?f=23&t=6182
Posted: 10 Apr 2013, 20:33
by bromatofiel
Hello,
I'm trying the Altap Translator 1.20 and it seems quite powerfull. As a software developper myself, I'm impressed !
I started with the FTP plugin translation, and there still are some details I'd like to know. As some other languages, French translation is quite often longer than English sentences. And it seems that the text area is locked to the size of the original English sentences. Is that correct ? Can I "manually" set the appropriate size ? And if not, how is German translation even possible !
Otherwise, there are lots of translations to do in a single plugin. Do you need that we do all the work in one strike, or is it better to send you the begining so other translaters may continue ?
Thank you for your answers.
Posted: 10 Apr 2013, 20:49
by Petr Solin
Thanks! I think Altap Translator is really powerful utility. We are still improving it, mainly its validations (text clipping, hotkeys conflicts, slightly misaligned controls in dialog, etc.). Also dialog layout editor is more powerful then MSVC one.
We also use it to import all translations to newer versions automatically. I think you will easily learn to use it if you want to.
But first please follow steps in this post:
You can make controls in dialogs wider in dialog layout editor, see readme.txt in Altap Translator folder.
If you don't want to bother with dialogs layout editing, I can do it when you send me translated module (in .slt file, see readme.txt). Try to translate whole module, I think that if someone elso wants to help, he or she can choose another module, so there is no chance for any collision between translators.
Posted: 27 Jan 2016, 22:51
by bromatofiel
Starting french translation of plugin renamer.atp
Posted: 29 Jan 2016, 08:02
by Petr Solin
I have received translated Renamer plugin yesterday. Thanks to Bromatofiel!
Posted: 02 Feb 2016, 13:55
by ADB
Je vais m'occuper de Zip.atp
I will work on zip.atp for now
Arnaud
