Dutch version of Altap Salamander
Forum rules
Re: Dutch version of Altap Salamander
Great, please just download latest version of Translator: http://forum.altap.cz/viewtopic.php?f=23&t=7340
And you can fix anything you want except FTP client. The last message from CeSium was about modifying FTP client, so I think everything else is possible to change. I do not know about anyone else working on Dutch translation.
You can use batch Salamand 3.0 beta 4\projects\Dutch\!translate2.bat to find untranslated texts. See readme.txt for details.
canefield
Post by canefield »
Petr,
Does it appear that all plugins are been translated? Or am I missing something.
How about the list?
KR,
Canefield
I have used !translate2.bat and it has found FTP with 1251 untranslated strings and some other incompletely translated plugins. FTP is locked by Cesium (I have sent him also email, I'm waiting for reply now), so do not work on it.
Here is the list of plugins which need review and translating of few untranslated texts:
splitcbn
unace
unarj
uncab
undelete
unfat
unchm
uniso
unlha
Please use batch Salamand 3.0 beta 4\projects\Dutch\!translate2.bat, it shows FTP first, when you close window with FTP, it shows splitsbn, when you close window with splitcbn, it shows unace, etc. When you are in Translator window, use Ctrl+U key to find all untranslated texts, then use F4 key to focus first untranslated text, translate it and press Ctrl+Enter key to move focus to next untranslated text, again translated it and press Ctrl+Enter key, etc.
These plugins needs only review - read all texts in dialogs and menus and string tables (e.g. some texts are only partially translated - contain English parts):
tar
unmime
unrar
wmobile
zip
As a part of review you should try to validate translation (Ctrl+Q key). Do not solve dialog layout errors (e.g. clipped texts), I'll fix it on all plugins when translation is done (when all texts are translated).
CeSium
Post by CeSium »
I have reviewed and translated all modules 7zip.atp ... salamand.atp.
This leaves modules splitcbn.atp ... zip.atp open for review and/or translation.
@Canefield:
Currently i am working on the FTP module, so feel free working on the other modules S...Z
I think it should be easy to avoid translation collisions as long as it is only the two of us... :D
We will release new version of Salamander at the end of this week. If you have anything patched or newly translated, please let me know or better send me exported .slt files. Thanks!
superBK
Post by superBK »
CeSium wrote:I have reviewed and translated all modules 7zip.atp ... salamand.atp.
@Canefield:
Hi Cesium,
I've just reviewed your 7-zip translation and i found some mistakes. Here are the improved ones, please update your 7-zip translation
Dialog
-IDD_CONFIGURATION<1200>
IDC_CFG_SOLID_ARCHIVE: Maak &solide archief aan
IDD_NEWARCHIVE / IDC_CFG_SHOWEXTENDEDOPTIONS
-IDD_NEWARCHIVE / IDC_CFG_SHOWEXTENDEDOPTIONS: Maak nieuw archief aan
-IDC_CFG_SOLID_ARCHIVE: Maak &solide archief aan
IDC_CFG_EXTENDEDLISTINFO / IDD_ENTERPASSWORD
IDC_STATIC_1: Dit bestand is versleuteld. Voer a.u.b. het wachtwoord in voor het ontcijferen van het bestand.
String Table
<922>
-IDS_PLUGIN_DESCRIPTION: Creëer, blader en pak 7-Zip archiefbestanden uit.
<1008>
-IDS_CANT_CREATE_ARCHIVE: Kan het archief niet aanmaken.
-IDS_INCORRECTPASSWORDBODY:
Het wachtwoord is onjuist. Gelieve het wachtwoord opnieuw invoeren. De letters in het wachtwoord kunnen\n hoofdletter gevoelig zijn. Wees er zeker van dat de CapsLock niet per ongeluk is ingeschakeld.
<1024>
IDS_UPDATE_NOT_SUPPORTED:Bijwerken worden niet ondersteund voor dit archiefbestand.
IDS_7Z_SOLID_DELETE_UNSUP: Verwijderen van bestanden in solide archiefbestanden wordt niet ondersteund.
IDS_CREATE_NEW_ARCHIVE: Maak nieuw archief aan
<1088>
IDS_BTN_RETRY: Opnieuw proberen
IDS_ERRADDDIR_TOOLONG:Één of meerdere mappen kunnen niet toegevoegd worden aan de lijst. Het totale pad is te lang.\nEnkele mappen of bestanden kunnen ontbreken in het achiefbestand.
canefield
Post by canefield »
Hey Guys,
Sorry for the delay...I'm now finished with verifying and further translation of 'uniso.slt', 'unace.slt', 'unarj.slt', 'uncab.slt' & 'undelete.slt' in AS v3.06.
So update the list!
unace.slt - Canefield - done
unarj.slt - Canefield - done
uncab.slt - Canefield - done
undelete.slt - Canefield - done
uniso.slt - Canefield - done
Bye,
Canefield
undelete.zip
(2.87 KiB) Downloaded 1855 times
uncab.zip
(1.69 KiB) Downloaded 1863 times
unarj.zip
(1.67 KiB) Downloaded 1904 times
unace.zip
(1.64 KiB) Downloaded 2040 times
uniso.zip
(2.47 KiB) Downloaded 1873 times
canefield
Post by canefield »
Guys,
Please an updated list what's not completed yet. As for example, I see no further actions concerning the 'tar.atp' in AS 3.06 although its mentioned in the list.
KR,
Canefield
Thank you for working on it!
Please use Ctrl+U key in Translator for Undelete. There are 120 strings marked as untranslated. To see untranslated strings use F4 key (after Ctrl+U key). To mark string as translated use Ctrl+Enter (it also moves to next untranslated string).
canefield
Post by canefield »
Petr,
Am I missing something...?!
When checking the uploaded 'undelete.slt' for instance, all words/phrases are translated. All the output I can see is in Dutch although it marks 121 occurrences. Am I doing something wrong?
UPDATE: you may mark/toggle all uploaded '*.slt' as translated. :-)
KR,
Canefield
OK, done.
canefield
Post by canefield »
Guys,
The new reviewed and changed work:
unfat - Canefield - done
unchm - Canefield -done
unlha - Canefield - done
tar - Canefield - done
unmime - Canefield - done
unrar - Canefield - done
wmobile - Canefield - done
zip - Canefield - done
splitcbn - Canefield - done
@Petr; #1 this time I've used the toggle switch :wink: #2 Would you update the entire list? #3 Not all finished translations are correctly shown by name. Not that I mind, only for observation. Main purpose -> having everything translated.
Bye,
Canefield
splitcbn.zip
(2.07 KiB) Downloaded 1916 times
zip.zip
(10.63 KiB) Downloaded 1853 times
wmobile.zip
(1.82 KiB) Downloaded 1830 times
unrar.zip
(2 KiB) Downloaded 1852 times
unmime.zip
(1.05 KiB) Downloaded 1797 times
tar.zip
(1.26 KiB) Downloaded 1903 times
unlha.zip
(939 Bytes) Downloaded 1844 times
unchm.zip
(938 Bytes) Downloaded 1805 times
unfat.zip
(798 Bytes) Downloaded 1830 times
Thanks for review! I have not found any changes to TAR plugin. Never mind. ;-)
There is only one unfinished plugin now: FTP Client. All others are translated and validated. Main module of Salamander too.
I have sent email to CeSium to tell us current FTP translation status.
@Canefield:
#1: very well ;-)
#2: it seems the list is no longer needed
#3: I don't understand, try to describe it with more details
CeSium
Post by CeSium »
Hi guys,
Here's an update to the FTP module.
It's still not complete, but before going on vacation i thought somebody else could jump in and help me on this.
I finished translating the dialogs. No final check has been done however. It may need some fine tuning.
String tables and menus are still open for translation.
@Canefield...if you could jump in maybe we can complete the FTP module together :).
ftp 2015-07-11.zip
Incomplete FTP translation
(21.58 KiB) Downloaded 1889 times
canefield
Post by canefield »
Guys,
I've translated FTP until 'String Table'. So it isn't finished yet. I'll be off for holiday.
@Petr: what I was trying to say with point #3, that not the right names were matched to their translator. Never mind.
Bye,
Canefield
ftp 2015-07-14.zip
Incomplete FTP translation. Please start translating starting from 'String Table'.
(21.07 KiB) Downloaded 1828 times
