permanent error 4 copying files
Posted: 25 Mar 2015, 17:04
i try to copy a lot of files (a lot of means maybe 20000 - 30000). the files are small like epub and mp3.
after a long time Salamnder is check the files it starts the copy.
now always after a few files(maybe 100) i get the error message (Fehler(4). Das System kann die Datei nicht öffnen).
Means translatetd: Error(4). the system cannot open the file.
if i wait a minute or less and press retry, the copy runs and after a few files the same procedure.
I'm not sure its really a problem of salamander, can be also a problem of the system
(maybe not enough handles or anything like that).
I use windows 7 64bit in german. and is use Altap Salamander 3.06(x64).
Anything i can do beside pressing million times "retry" ?
Thanks
Mike
Thanks
Mike
