IPhone connection not visible in Salamander?
chwdgr
Post by chwdgr »
Hi! When I connect my IPhone via usb to my PC, then Windows Explorer shows
this as an extra drive. Salamander however does not!
Is there an option to activate Salamander to show it also?
Just a simple question, not urgent!
Thanks anyway!
Chw de Graaff
Re: IPhone connection not visible in Salamander?
Have you used search on this forum?
Salamander does not support what Microsoft calls namespace, but only filesystems. There might be work-arounds using plugins or device settings, though.
Yuriy
Post by Yuriy »
The only way I was able to display IPhone directory in Salamander is through T-Pot plugin fot Total Commander - via Total Commander Proxy.
Unfortunately, it exists only in 32-bit version, not 64, and was not updated since 2010.
