Problems with UnISO file association - .cif
Posted: 27 Jul 2014, 18:25
Hello,
first of all I want to say that I am a long term happy user of Servant salamander, a program which should be found on every computer!!
Now I have a small but annoying problem:
The UnISO-plugin does an "unfriendly take over" of the .cif-file association! This leads - at least in my case - to severe trouble.
The .cif-file is the standard file for handling X-ray crystallographic data. Its structure is defined by the International Union of crystallography (IUCr). After an update of Servant Salamander, I was unable to change the .cif-file association back to my standard (CCDC-Mercury, a program to handle such files). It would be extremely helpful if one could choose during the process of installation or update of Servant Salamander if this association will be installed or not.
Best regards,
Thomas
Best regards,
Thomas
