FTP: date+time sorting
Mem
Post by Mem »
I accidentally find out that FTP plugin can not sort date+time column but only date (standard SS panel bounds these columns together). So I can not sort chronologically files for the same date (time column is even not clickable).
Is it possible to fix this?
Yes, we will try to patch this in version 2.5 RC2.
Mem
Post by Mem »
Great Image
adaz
Post by adaz »
Hello,
The sorting is bad in the RC2 version too. Can you fix this?
Thanks!
Yes, we still plan to patch it. It does not seem to bother a lot of people so we still have something more important to do.
I've just came to the same problem :(
I have this problem on Pipni servers. According to Pipni home page, they are hosting around 42 750 domains. That seems to be big group of users ;)
This is general problem. Whenever you are sorting by date or time when FTP is in panel, you can see this problem. I'll fix this (I'll add support for grouping of columns) after other more frequently wanted things.
