Application Icons not correct
Posted: 16 May 2006, 15:40
by lwetzel
I hadn't noticed this problem untill someone in my office noted it. All application icons are incorrect. Is there a way to change this? I can't seem to find it and maybe I am overlooking it. They all seem to be Wordpad or folder icons. WinZip files are folders with a page in them. Any help here??
Posted: 16 May 2006, 20:28
Try to open Windows Explorer for the same directory (Shift+F3 from Servant Salamander) and compare displayed icons. Could you send us screenshot with both (Windows Explorer and Servant Salamander) windows displayed?
Posted: 17 May 2006, 00:01
by AbteriX
Hi lwetzel,
could you please check if "Drives | [x] Use simple Icons"
is checked ?
You'll find this unter "Options | Configuration..."
HTH ?
Problem fixed
Posted: 17 May 2006, 19:20
by lwetzel
Thanks AbteriX,
"Drives | [x] Use simple Icons" was checked for Network Drives and it is now working correctly. I knew I was missing something.
Thanks again.
Posted: 17 May 2006, 19:57
Thank you AbteriX! I overlooked the most obvious answer
