can't open large size jpg in pictview
Posted: 18 Jun 2014, 22:59
by omega
I have a jpg file of 480 MB, pictview can't open it and display the following error: out of memory
Windows built in image viewer can though it took couple of minutes to generate it.
Re: can't open large size jpg in pictview
Posted: 20 Jun 2014, 20:59
by SvA
What are the image dimensions (width, height, color depth).
Are you on x86 or x64 Windows?, 32 or 64 bit AS?
Posted: 24 Jun 2014, 04:26
by omega
Width: 27419 pixels
Height: 21012 pixels
Color: TrueColor 24Bit
Format: JFIF 1.1
Compression: Lossy + Huffman coding
Size in memory: 1728384084 bytes
File size: 503683764 bytes
OS: Win 7 x64, running AS in 32 bit
Posted: 24 Jun 2014, 07:04
by Jan Patera
omega wrote:I have a jpg file of 480 MB, pictview can't open it and display the following error: out of memory
Running AS in 32 bit
Well, this is an expected behavior. 32bit AS can in theory allocate up to 2 GB. Given memory fragmentation and other needs of AS, its plugins and other DLL's loaded into its memory, it is quite unlikely that PV could allocate 1.7GB for a single image.
Posted: 15 Jan 2016, 12:31
by RoyalB
Hi Jan, I have a 1.4gb image and 32bit AS so I thought I would be fine considering that 1.4gb is below 2gb but I can't open my image either. Does this mean I need to buy more memory?
Posted: 19 Jan 2016, 13:49
If you have 4GB RAM, more memory would not help. The problem is probably in PictView allocating large memory blocks. 32bit memory space is fragmented by DLLs, heaps, etc.
