Hi
When I try to drag and drop a file from an email (attachment in OL2003) to AS3.0 x64 I get the Forbidden mouse cursor symbol instead of the + thingy and it can't be dropped.
I'm on W7pro x64.
McL
Drag & Drop in AS3.0 x64 mot working
Re: Drag & Drop in AS3.0 x64 mot working
Do you run AS or Outlook as administrator?
Yes, AS as Administrator.
Just tried not as Admin and then it works.
We need to support UAC escalation, it will be included in AS 3.1. It will solve this problem, you will not need to run AS as administrator.
I do run as Administrator mainly to be able to create folders in C:\Program Files\...
So, this will be covered in AS3.1 ... great
Thanks
McL
btw: If you implement new looks .. please keep option to set it to the look it has now!
Thanks
McL
