error loading configuration
Posted: 07 Nov 2013, 20:46
by roel@ozemail.com.au
On starting AS, an error box comes up...
Error Loading Configuration
(5) Access is Denied
After pressing OK, AS loads as normal, apparently with configuration intact. There seems to be no ill effects while using the software, and when closing, it seems to save the configuration and close normally.
This occurs at each startup...
Re: error loading configuration
Posted: 07 Nov 2013, 22:59
Create a new user profile and try salamander there. Its highly possible thaht your registry is corrupted.
Go Options > Export configuration and store it on a safe place.
As a quick fix, you can delete the HKEY_CURRENT_USER\Software\Altap key and subkeys.
You have to re-configure Salamander or you can import the stored configuration.
Posted: 08 Nov 2013, 03:10
Thank You for your prompt reply. I'm sorry, but that did not work for me...
Any other thoughts?
Roel
Posted: 08 Nov 2013, 07:19
What did not work? creatin a new user profile or deleting the registry hive?
Posted: 18 Nov 2013, 09:55
by Tomas Kopal
Can you, please, check if you don't have an exported configuration file present in your salamander install directory? Maybe it is there and is not readable. Citing the help:
"If you save the configuration to a file named config.reg and place this file to installation directory (near salamand.exe) or in Vista or later rather in application data directory (typically C:\Users\<user>\AppData\Roaming\Altap\Altap Salamander), that configuration will be imported from this file to the registry before loading Altap Salamander's configuration from the registry."
