WinSCP plugin - "Upload Options" are always disabled
Posted: 14 May 2013, 15:48
A Co-worker of mine noticed that unlike in WinSCP the Permissions options in the Copy Transfer Settings dialog are always disabled. Testing the same connection with WinSCP shows the options enabled with the same SFTP server (since the settings are shared it should be pretty much guaranteed that the settings are identical).
Changing the the preselected Permissions in the global WinSCP Plugin settings works but my Co-worker needs several different patterns frequently so that isn't a good solution.
I tested both the current beta as well as the release version. In both cases I was unable to set permissions to be applied on upload.
MFG
-blkhawk
MFG
-blkhawk
