Viewer doesn't show text files correct
Posted: 27 Apr 2006, 21:39
Some files are not shown correct in the viewer. All chars are shown in a vertical line.
Is this a codepage/coding problem?
www.altap.cz
https://forum.altap.cz/
Can you verify that the file is not Unicode encoded? (e.g. switch to hex-view and check if every letter is not followed by a zero).Eric wrote:Some files are not shown correct in the viewer. All chars are shown in a vertical line.
It's an unicode file. Are there any plans to support Unicode? I thinks it's a important feature.Tomas Kopal wrote:Can you verify that the file is not Unicode encoded? (e.g. switch to hex-view and check if every letter is not followed by a zero).
Internal viewer does not support Unicode texts yet.
You are not alone.Eric wrote:It's an unicode file. Are there any plans to support Unicode? I thinks it's a important feature.
This is a very useful tip. Lister32 nearly looks like the internal viewer and is integrated very well in Servant Salamander. I use it on first place in my list of alternate viewers so I can reach it easily with ALT+F3.Stefan wrote:I use Lister32 from Mr. Ghisler for unicode files.
