bug report in pictview - scanning in x64
zxspectrum
Post by zxspectrum »
hi, i wanted to make a scan with pictview, thing that i do very often with 2.54 and it works great (only problem is i cannot scan in pdf format)
today, i tried to scan with 3.0 beta,and i get this error mesage when i try to select scanner source (attach)
P.S. i dont even get to select source...as this message appears right after clicking the "select scanner source".
I should mention that pictview in 2.54 works just fine
Hope my post will help fix the bug
If you need more information please tell.
twain source manager - Untitled.jpg (364.97 KiB) Viewed 16782 times
Re: bug report in pictview
Are you using 32-bit or 64-bit version of Salamander?
zxspectrum
64 bit version...havent tried on x86
Could you try it? - so we can know whether it's a problem related to the 64-bit version, or to some other changes made between v2.54 and v3.0b.
zxspectrum
well, i just tried x86 version but only on windows xp (x86) for now i dont have any w7 x86 to test it on....and it works,i could select the scanner source and i even got to scan the page....so i guess the x86 verion works....
That doesn't matter.
You can still run the 32-bit version of Salamander on Win7 x64.
(It is the opposite that you cannot do. You cannot run 64-bit Salamander on [any] x86 OS.)
zxspectrum
you are right...i can always install x86 version of salamander on x64 system...so i did that and it works , the plugin works as it is supposed to do, i can select the source and then scan ...
so everything works as it should...guess the problem is in x64 version.Good luck with that.
P.S. hope you implement a "scan to PDF" function as the jpg format is getting obsolete.Thank You
Re: bug report in pictview - scanning in x64
We have added support for scanning using WIA to version 3.07 x64. TWAIN x64 seems to be much less popular, so we will not support it now.
contich1940
Post by contich1940 »
therube wrote: 12 Oct 2012, 00:55 > i dont have any w7 x86 to test it on
Yes, he is right you can also run a 32-bit version of salamander on Win7 x64.
