ID3 Tag - missing field
Posted: 20 Sep 2011, 08:41
by kretb
Is it possible to modify the fields which are shown when you use the Viewer to show MP3 tags.
I'm missing f.e. the field "Disc-No.".
And many often the URL is shown in Japanes Letters and when I open this file in another ID3 Tag Editor this field is shown correct.
/Bernd
Re: ID3 Tag - missing field
Posted: 21 Sep 2011, 21:16
by Ether
kretb wrote:Is it possible to modify the fields which are shown when you use the Viewer to show MP3 tags.
Nope. It's just a viewer.
kretb wrote:And many often the URL is shown in Japanes Letters and when I open this file in another ID3 Tag Editor this field is shown correct.
Could you post a screenshot of what these Japanese letters look like?
Posted: 22 Sep 2011, 14:31
by kretb
I mean, I don't want to modify the entries in the fields, I mean I want to see the Field "Disk", which shows me the discnumber.
I get many field but not this one and it have definetly an entry, because I made this entry with a different program (MP3Tag) and can see this entry afterwards f.e. in the Windows Explorer.
Could it be that this is relating to the adjusted language in AS?
What is the best way to post to post a screenshot, is drg'n drop possible?
/Bernd
Posted: 22 Sep 2011, 22:28
by omega
if you go to upload attachment you can post the screenshot
Posted: 24 Sep 2011, 12:08
by kretb
okay, enclosed the Screenshot, on the left side you see the information out pof mp3tag and left side the mp3 viewer inside AS.
So you see that also the discnumber is not shown in the viewer
/Bernd
Posted: 24 Sep 2011, 22:51
by omega
The Multimedia Viewer plugin doesn't have the field disc number that's why you don't see it.
PLUS i don't see that the URL is shown correctly in your ID3 TAG WWW field "Soundcolours gmbh .... " ??? And those are not Japanese letters but Chinese characters.
Posted: 25 Sep 2011, 20:35
by Ether
Could you check the Extended Tags dialog to see all the fields? I think that the Mp3tag's WWW and Multimedia Viewer's URL are different fields.
Posted: 26 Sep 2011, 11:52
by kretb
No, the fields are definitely the same (Mp3tag's WWW and Multimedia Viewer's URL).
Are you able to show all the extenden tags in a file?
/Bernd
Posted: 28 Sep 2011, 16:17
by Ether
I tried to save something into the WWW field in a MP3 file using Mp3tag and it didn't show in Multimedia Viewer, so I was thinking it is a different field. If you could show us all the fields (using the Extended Tags feature of Mp3tag), we could see what field we're really talking about.
Posted: 28 Sep 2011, 19:54
by kretb
I was sending you a PM.
/Bernd
Posted: 28 Sep 2011, 20:45
by Ether
OK, I replied. I hope we'll find the reason for the wrong URL.
In the meantime, I created another
topic for the disc number field in the Feature Requests section.
Posted: 29 Sep 2011, 10:02
by Ether
So, according to the sample you sent me, the culprit seems to be the WXXX tag. The content seems to follow
the spec with ISO-8859-1 encoding, but IMO Multimedia Viewer assumes it's in UTF-16 as the rest of the tags and maybe even doesn't skip the Description part.
Below are samples - first is the original tag which displays incorrectly, second should be the same text in another tag (not custom) which displays correctly. A screenshot with both the tags in Multimedia Viewer is attached.
57 58 58 58 00 00 00 26 00 00 01 FF FE 00 00 77 77 77 2E 6D 79 73 70 61 63 65 2E 63 6F 6D 2F 62 61 72 6C 6F 75 6E 67 65 63 6C 61 73 73 69 63 73
WXXX...&...˙ţ..www.myspace.com/barloungeclassics
57 4F 41 52 00 00 00 21 00 00 77 77 77 2E 6D 79 73 70 61 63 65 2E 63 6F 6D 2F 62 61 72 6C 6F 75 6E 67 65 63 6C 61 73 73 69 63 73
WOAR...!..www.myspace.com/barloungeclassics
Posted: 21 Oct 2011, 16:18
by Jan Patera
/Bernd
Can you please provide a sample .mp3 file with these problems? Your descriptions are clear, but we need sample file to fix them.
Posted: 24 Oct 2011, 09:54
by Ether
Attaching a sample with DISCNUMBER and WWW fields.
