Disabling "Parent Directory" shortcut icon
Posted: 14 Jan 2022, 00:04
by roothieboi
I wanna disappear/remove Parent Directory shortcut icon from inside of main frame but i couldn't found the solution anywhere, please help.
Because when in thumbnail mode and zooming in; looks terribly disturbing.
Please help.
Re: Disabling "Parent Directory" shortcut icon
Posted: 15 Jan 2022, 20:23
Such feature is not available. It's the second time I am answering this question.
Posted: 17 Jan 2022, 10:46
by tukanos
roothieboi wrote: ↑14 Jan 2022, 00:04
Please help.
You probably just want to imitate the Windows Explorer behavior. The sad truth is that Windows Explorer is missing this in the default configuration and MS should add it. This is actually a std. way file managers are displaying the need to go up a directory. Salamander does not have the option to remove it as it wouldn't make sense.
