I keep getting an error when I try to view a CSV file, no problems with text viewer or editor, only when I press F3.
I am wondering if this isn't a specific x64 version error.
I error that does not allow me to send the bug report, some syntax and server error (see attached screen image)
The bug report is too large to attach
Altap Salamander V4.0 (x64)
- Altap-Reportsend-error.png (21.44 KiB) Viewed 4457 times
Hans
"IT" Always crosses your path...
Hans
Re: Altap Salamander V4.0 (x64)
It is probable that it is the same issue as discussed here viewtopic.php?p=68092. There is a patch available, try to update it.
