[Solved] Shortcut for hot path not work
Posted: 08 Aug 2019, 06:18
by Yanjin
I set several hot paths, but the hot key 'Ctrl + 1, 2, ... not work, the panel didn't change to corresponding path.
Software version is 4.0(x64)
OS version is win10 x64 1903
Update:
The shortcut works after I reinstalled it.
Re: Shortcut for hot path not work
Posted: 08 Aug 2019, 21:58
by therube
Looks to be working as expected on my end.
Win7 & Win10 (1803, I think it was), Salamander 3.08 & 4.0.
Anything "odd" with the path you're using?
If you copy the path's value (to clipboard), can you Shift+Ins to switch to it in one of the Salamander panels?
Posted: 10 Aug 2019, 14:02
Please show us a sample of your hot path configuration.
Posted: 10 Aug 2019, 17:10
by Yanjin
@therube and @SelfMan, thanks for your replying.
Today I reinstalled it, and now the shortcut works.
Re: [Resolved] Shortcut for hot path not work
Posted: 10 Aug 2019, 17:29
You are welcome
