Cannot delete file, cannot read source...
Posted: 11 Aug 2010, 11:25
by Pimpa
If I have a file with name contains these characters (ű,ő) the Salamander's panel replaces them with (u,o) accordingly.
Trying to delete, copy or move this file, it is impossible. I got a message "Cannot delete file: Cannot read from the source file or disk."
I tried to set Panel Font MS Sans serif Western to Central European, but nothing changed.
Any suggestions please?
This problem is in Salamander 2.53 now, but in any earlier versions too.
Thanks,
Pimpa
Re: Cannot delete file, cannot read source...
Posted: 11 Aug 2010, 16:33
by omega
ű and ő are not in the ASCII standard but in ISO 8859-2
Posted: 11 Aug 2010, 21:04
by Ether
Can you handle those files properly in Windows Explorer? If so, are there any other non-ASCII (i.e. not in the English alphabet) characters you encounter in your file names? If not, you could change your non-Unicode locale to German (I assume those are standard umlauted o and u contained in the Windows' German character set). That should take care of any further problems.
For more information and a walkthrough, refer to the
Unicode Support page in Salamander's help.
If that doesn't solve your problems, please tell us the version and language of your Windows, as well as the value of the non-Unicode locale setting.
Posted: 12 Aug 2010, 11:46
by Pimpa
Ether wrote:Can you handle those files properly in Windows Explorer? If so, are there any other non-ASCII (i.e. not in the English alphabet) characters you encounter in your file names? If not, you could change your non-Unicode locale to German (I assume those are standard umlauted o and u contained in the Windows' German character set). That should take care of any further problems.
Yes, I can handle these files in Windows Explorer properly. File names contains other non-ASCII characters, but only this two causes error. The mentioned Unicode Support Help solved my problem.
Thanks a lot.
Regards
Posted: 17 Nov 2013, 09:06
by tpalenik
It happens also with many other accented characters.
Easy steps to replicate: In windows explorer create a folder named "Čeština".
Now try to open or move or delete it in Altap Salamander - you get an error.
Windows explorer and other file managers handle this with no problem.
This is a VERY serious problem for a file management software - Altap team, please fix.
Tried multiple times on several Windows 7 versions (32 and 64 bit - all english systems).
Altap salamander ver 2.54.
Posted: 21 Jan 2014, 19:41
by lexa
Ether wrote:I assume those are standard umlauted o and u contained in the Windows' German character set
ű and ő are not German, we have Ä + Ö + Ü + ä + ö + ü + ß (Umlaute) and I had never any Problem with that chars since Salamander v1.51 and Windows 95.
Just my 2 cents
Posted: 23 Jan 2014, 16:41
by Ether
lexa wrote:ű and ő are not German
My fault, thanks for noting that. They're actually Hungarian characters. Also, German characters are contained in the default English character set (Win-1252 / ISO-8859-1 / CP437).
tpalenik wrote:Now try to open or move or delete it in Altap Salamander - you get an error.
In case you know the characters you'll be working with in advance, you can change your "non-Unicode locale" setting to a different language or use AppLocale. Alternatively, if none of the provided national character sets suit your needs, there is an unofficial way to create a custom character set. If you need any help, let us know.
