Automation Plugin: Fails to recognize AppPath
Posted: 19 May 2010, 17:05
I just discovered the Automation Plugin. Wow!
I created my first "Hello World.vbs" script. I put it in the directory "C:\Documents and Settings\TimeGhost\Application Data\Altap\Altap Salamander\Automation\scripts" but it doesn't show up on the list of scripts.
So then I added that path into the plugin's list of directories, restarted Salamander, and saw my Hello World script.
I used the set command to verify that the AppPath environment variable is set properly.
So I suspect the $[AppPath] environment variable isn't being expanded properly. Work around: specify the entire path, for now.
Plugin version: Automation 1.1 beta 1
Salamander version: 2.53 B1
OS: Win XP SP3
OS: Win XP SP3
