Sony Walkman
Posted: 19 Feb 2010, 21:11
by dgray
My Sony Walkman E-series (NWZ-E-345) isn't seen/recognized by Altap (ver 2.5.2) as a removable storage device. But it is seen and recognized by Windows Explorer. Does anybody know why?
O/S: Window XP Professional, ver 2002, service pack 4
Re: Sony Walkman
Posted: 19 Feb 2010, 21:48
It probably doesn't support USB Mass Storage. Could you access it from Command Prompt?
Re: Sony Walkman
Posted: 19 Feb 2010, 22:35
Have you installed some drivers for the player?
Re: Sony Walkman
Posted: 01 Mar 2010, 18:44
by Mem
Just to confirm the behaviour:
I have read that for some users works UNC path such as "\\WALKMAN" (not on my Win7 x64 though)
The problem is that the device is not using USB Mass Storage driver by default, but some Media Transfer Protocol (MTP) instead (see this thread in Total Commander forum:
http://ghisler.ch/board/viewtopic.php?p=160881#160881). So Altap may consider implementing this protocol for us.
Another workaround is to manually reinstall the driver for the player (info from
this TC forum thread):
- go to device manager
- locate walkman and go to properties
- select driver tab
- refresh driver... (i don't know if this is the correct translation)
- select install from a list.. -> next
- don't search -> next
- select USB mass storage device (the other is MTP device)
- you're done (the walkman gets a drive letter)
And the workaround works
Re: Sony Walkman
Posted: 01 Mar 2010, 19:41
You can try to run mentioned TC plugin in Salamander, using Manison's
Total Commander Proxy Plugin.
Re: Sony Walkman
Posted: 19 Jul 2010, 17:21
by mystrdat
Sorry for the slight necromancy, but are there any news considering the MTP (PTP) protocol support in Salamander? I'm coming around a lot of MTP devices lately.
Although I have to say that changing to mass storage driver (as mentioned above) instead of the MTP device is a good solution and works well, MTP might still be worth a consideration (or not). I guess I'm just asking if you plan on ever supporting MTP or not at this point.
Re: Sony Walkman
Posted: 19 Jul 2010, 17:59
We don't plan it right now. It is possible to implement it as
Altap Salamander plugin based on protocol specification, (or Mr. Ghisler released source code for his
Windows Media Audio for MP3-Player plugin at
http://www.ghisler.com/plugins.htm#filesys but I don't see the license agreement there - it would require to contact him).
Another "easy" option is use his compiled TC plugin with Manison's
Re: Sony Walkman
Posted: 01 Aug 2011, 18:52
by achillies000
Re: Sony Walkman
Posted: 03 Apr 2013, 13:37
by Hyperlife
Re: Sony Walkman
Posted: 18 Jun 2013, 09:26
by merlin
Hello,
I am also supporting this request - MTP is now standard protocol for many mobile devices including the new mobile phones. it is shame that Altap Salamander is not supporting it. Frankly, I don't really understand what Altap developers are doing for so many years between version 2.54 and 3 when they are not able to reflect the key changes in the industry... I see almost no additional features in 3 vs. 2.54 that users would REALLY see. MTP would be one key feature... as said, it is now everywhere and Altap Salamander, as the replacement of Windows Explorer does not support it
Quite disappointing...
Re: Sony Walkman
Posted: 23 Jan 2016, 10:37
