Mapped drives not visible
McYoda
Post by McYoda » 23 Feb 2017, 19:30
Hi there
Using AS since years. Best investment ever ;-)
But now I've got a problem.
Environment:
Windows 10 x64
Salamander 3.08 x64
When I map drives using a batch file with "net use ..." commands, Windows Explorer shows the mapped drives. But Salamander seems to now nothing about the drives. Even when I map them using Salamander menu, they are gone after restart, even if I enabled them to be persistent.
You can see in attachment.
I tried to close Salamander and reopen. No success.
I tried starting batch file with Salamander closed or opened. No success.
This is very annoying. Never had these problems on Win7 or before with Salamander.
Thanks for help
Martin
Re: Mapped drives not visible
Post by SvA » 23 Feb 2017, 19:48
Does Salamander run as the same user and with the same integrity (UAC elevation level) as Windows Explorer?
Have you been searching this forum for mapped drive?
The following thread seem particularly promissing:
Mapped Network Drive not shown
