Side effects on attribs on deleting a read-only hardlink
Posted: 17 Feb 2016, 14:20
by wqweto
There is a a read-only file (e.g. under source control) and I make a hardlink to it with `c:\temp>mklink /h newname.txt c:\path\to\oldname.txt` so `c:\temp\newname.txt` hardlink inherits the read-only attribute which is an expected behavior.
When any of the `newname.txt` attributes are changed with File->Change Attributes (F2) command so are `oldname.txt` attributes and vice versa -- this is normal NTFS behavior.
Couple of issues with AS:
1. A minor one -- when both `c:\temp` and `c:\path\to` directories are open in AS, changing attributes on `newname.txt` in `c:\temp` is not reflected on `oldname.txt` in `c:\path\to` pane
2. A major one -- when deleting the `newname.txt` the attributes of `oldname.txt` get changed -- read-only attribute is cleared
I know why this happens but it's a very unexpected behavior.
Here is a blog entry on how to enumerate all the hardlinks for a file
https://blogs.msdn.microsoft.com/oldnew ... 0/?p=10103
cheers,
</wqw>
Re: Side effects on attribs on deleting a read-only hardlink
Posted: 17 Feb 2016, 16:38
by Petr Solin
Thanks for reporting this! I have tested with Explorer (in Windows 7) and TC and neither solves this problem. Salamander and TC clear more than only read-only (RO) attribute, Explorer clears only RO (other attributes are not changed), it's surely better behavior. Now I'll fix our code to clear also only RO. I will do more complex patch to fully fix this problem sometimes later, currently I'm afraid of slowdown of delete operation and do not want to spend time experimenting with this. Thanks for understanding!
Posted: 17 Feb 2016, 17:34
by wqweto
Petr Solin wrote:. . . currently I'm afraid of slowdown of delete operation and do not want to spend time experimenting with this.
The hardlinks enumeration has the potential to slow down deletion of *read-only files only*, provided that there is no need to restore other attributes after deletion for writable files. Also, a possible optimization is to terminate enumeration just after the first alternative file is fetched -- should be enough to restore read-only attrib after the operation.
I'm wondering how can someone design a FS where file attributes are *not* part of the directory entry -- it's completely counter-intuitive. I don't even want to start researching what's the behavior of permissions ACLs with all the file hard/symbolic links, directory junctions and mount points scenarios.
cheers,
</wqw>
Posted: 17 Feb 2016, 20:11
by Petr Solin
Yes, only for read-only files, maybe only on local fixed NTFS drives, it has to be discovered, maybe later. :wink:
You can find some info in MSDN in documention for CreateHardLink function, section Remarks:
https://msdn.microsoft.com/en-us/librar ... 85%29.aspx
Posted: 05 Jul 2016, 16:53
by Ether
Or skip the restrictive Win32 layer. :) ZwCreateFile
Posted: 11 Apr 2019, 10:53
by wqweto
https://devblogs.microsoft.com/oldnewth ... /?p=102408 -- another useful article from theoldnewthing.
cheers,
</wqw>
