Tiny Toolbar Icons on Surface3 screen
dew
Post by dew »
I have a MS Surface 3 Pro tablet/laptop running Win10. Salamander ver. 3.06 (x64) runs fine on it. I have used Salamander for a very long time and would be hard pressed to work without it! However, as you can see on the attached screen shot, the toolbar icons are so small that I can't see them, let alone use them. I have looked through all of the documentation, and am able to increase the font size on the panels, but nothing on the toolbar height/ icon size. I saw one forum topic of over a year ago ("icon size not dpi aware"), but it did not include a solution.
Is there a way to increase the toolbar height / icon size?
Doug
Re: Tiny Toolbar Icons on Surface3 screen
As you already found out, Salamander is not DPI aware yet hence there is no solution yet. Its a work in progress.
You might want to try to set a lower resolution on the surface. HERE are some tips how to do it.
Georgd
Post by Georgd »
FYI, related posts are Icon size not DPI-aware and HiDPI support
Using Salamander since v 1.52
