been having unusual lockups when
opening files on the network or
when dragging a file from salamander
to another app. problem is not readily
reproducible though.
never experienced this problem with
older versions.
will try to pin-down a reproducable case.
other informations:
O.S. win xp pro 64. sp1
4G Ram
dual dual-core opteron 280.
-cpb
beta11_lock-ups
Is Servant Salamander definitely freezed?
Could you start second instance and using menu Help > Task List break the freezed instance? Bug report should be generated in the freezed instance...
These problems are often caused by faulty shell extensions, please look at http://www.altap.cz/salam_en/faulty_she ... sions.html for more information.
